2005 kx25f Hard to start
Just traded my 02 Cr125 in for the 4 stroke.
It starts fine when it is cold. But when Stahl it or crash it. Or just turn it off for a second when it is warm. I have to wait about 5 min for it to start again.
Please help..
Two probable problems:
(1) Adjust your fuel screw on the pumper carb. Just set your idle to highest possible revs and the turn fuel screw until maximum revs are reached. That is the correct fuel screw position. Next you adjust your idle back to where you would normally have it.
(2) After doing #1, always start your bike by first pressing on the kill switch and with a light push kick the starter through the range 2 or 3 times. That should clear out any excess gas. Next let go the kick starter and let her rip.
Bet those solve your problem. Both '05 KXFs start easy hot or cold in their normal state. We have had no problems once we broke the code on how to start them.
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
