Best year for CR 250
What would the best year for the CR 250. Im looking to get a fast bike and the big thumpers seem to hold their value too well :bonk: . What years had the best motor, trans, chassis etc.??? :applause:
From what I've read here it's 2001.
I've owned a 00', and my buddy has an 01'. While I really like those bikes, I still like my 03' better.
I know the 03's have a bad rep about a week motor, stock I agree, but if you have the money to pipe it and put a set of V-force reeds on it, it pulls really strong and smooth then. Not to mention the newer generation frame handles much better IMO.
2001 from what I have read also. My uncle just bought a 03 and it seems pretty fast although I just rode it for a min in the guys yard that was selling it as I was with him when he looked at it the first time. He ended up getting it for $2500 so it wasn't too expensive either.
2001 as far as motor goes..but if you have the money an 02-06 chassis with an 01 motor, it can be done !
That's exactly why I bought my 03 CR250 for under $3000. Lot's of bang for your buck. Fast and fun......not to mention light as a feather.
2001 CR is one of the greatest bikes ever made IMO.
I kind of am thinking maybe I should have bought one althoug I probably would have gone with an RM250 instead of rebuilding mine as I have put more into my motor on my bike than my uncle paid for the whole bike and mine probably wont be quite as quick as a 2-stroke but it will be fast.
I have owned a number of cr 250's, and in my opinion if you are looking for the best bike from 2000 on it would hands down be the 01. Granted the handeling of the newer frame was better, with just some slight suspension mods the bike handles with the best of them. Yhe motor was amazing. In fact i am looking at buying my old one back to give myself a green sticker bike.
I would have said a 1980.
Last year they made them air cooled, but I'm over 50.
Anybody got a basket case 1980 or 1979 they want me to take out their garage?
I would agree with the 2000 and 2001 models. If you want to know before the aluminum framed years,the 1996 is the best. My 96 had more holeshots then Ive had on my 2004. The 04 took a few mods to make it an ok engine. But I have said to the Mrs. that I would like the 96 motor in the sweet handling 04 model. Its just my opinion. And to the last guy that posted,my 1980 is a pooch. No its not for sale. Good Luck In your search :applause:
hey pgr11! What mods were you talking about. I have a chance to pickup a 01 cr250 for $1500. It is all stock only ridden a couple of times on trails.
I think the 88 was better looking. I woudl get that one!
I gotta ride one of those....
According to MXA the 1993 CR250 was the "ginzu knife" of motocross bikes when it came to cornering (perhaps it held its own against the RM?) but it suffered from severe headshake. It's safeto say the 93 is probably the "best" year of the steel-framed CR because of its awesome turning prowness...and MC won all his SX titles on a 93 chassis. As far as aluminum frame models, the 01 could be it, but I've seen 3rd gen frames (02-06) with the 01 motor..that is the best CR250 IMO and can be done with very little mod (head stay modification?)
I had a 1994 CR250 and spent considerable hours on a couple 2001 CR250's that some buddies had a couple years ago. Powerwise, the '94 and 01's were equivalent.
I've never ridden a >2001 so I can't say for sure, but I suspect that reports of the newer CR250R engine performance (or lack of) is the result of the greatly inflated parroting of magazine tests performed by riders with nothing of any redeeming value to report.
For me, I've never twisted the throttle on a CR250 and NOT instantly been aware that I am indeed on a CR250. For me, CR250's are as common and as consistent as Cheerios... once I get a taste, it's something that I can recall as tasting exactly the same for the majority of my life.
FWIW, I ride a 2001 CR500.
1993. From then wasn't ever the same. Great motor, and it turned very good.
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
