bar risers
can anyone suggest bar risers for a 2004 drz400s.. just got a new set of Oneal bars and they're the same hgt as the stock drz bars basically.. plus, if i raise the bars an inch or so, i can finally lower my front forks .5" (like i was supposed to do) since i put on a drz1 kouba link.. thanks
Use the "search" feature for "bar risers" in the DRZ forum and you will find ALOT of choices... :applause:
Try here.
Neil. :applause::bonk::cry:
I have an '03 DRZ400E and put on the bar risers I found at
They go on very easy with no cable problems. They raise the bar by 1.5 inches and forward by 1.375 inches.
I think the foreward mount bars may interfere with the computer on an S. I got my 1.5" from bigdrz but have seen them for less on ebay since then. They make for a much better ride standing, I don't feel like I'm reaching down for the bars.
Ebay has them. I think they were $34.95 buy it now option. :applause::bonk:
Same Price?? I paid $70.00 w/shipping.
My straight 1.5" risers arrived today from Andy at Big DR risers. Put them on already. They are saaweeet!
Thanks for a great product Andy. :applause:
I just ordered by 1.5" forward risers from Andy.
Whatever happened to the favorable US/Canadian exchange rate? I was thinking $105 CND would come out to 20 cents US. No such luck.
I also ordered from Andy. I think the risers with the extra material that fit into the cut-out just makes a cleaner, finished look.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
