Low idle/running dead spot on 400s???
Hello everybody,excellent forum :applause:
I have an annoying low throttle input dead spot,when traveling in slow moving traffic or turning into a side street when you go from no throttle(slowing down) to picking up the throttle to accelerate,makes the bike awkward to ride slowly :cry:
The bike is a 2000 model,totally standard,any help on the above to eliminate this :cry: problem would be much appreciated
Cheers,
Mick :bonk:
Sounds like the notorious "off-idle bog." Time to head over to the jetting forum and describe to Burned your altitude/jetting setup over there in the U.K. Be prepared to cut a hole and fiddle with the carb. :applause:
Hi MickB,
Welcome to ThumperTalk, sounds like it's time for the 3x3 and DynoJet kit.
Do a "search this forum" on "3x3" and "DynoJet kit" then head on over to Burned's jetting forum.
Neil. :applause::bonk::cry:
PS, where in the UK are you.
I'm in Southend
Cheers guys,i take it this is a common problem with these bikes then??
I'm from Northamptonshire by the way :applause:
Cheers,
Mick.
3x3 and dyno jet is the best $50 I ever spent. Makes your bike work SOOOO nice and keeps it fuel efficient, and dependable.
