whats the differance???
whats the differance between an xc,xc-w,exc-g,xc-g??? :applause:
The "G" just means its jetted lean to pacify Kalifornia
The "W" means wide ratio gearbox, which at this time only applys to two strokes, I expect 06 to have a "W" avalable in their off road versions of the 250SXF
450EXC, the E is a long stroke engine with an ultra wide ratio gearbox, this bikes claim to fame is in slopping thru mud, the long stroke engine maintains great traction, this is king of the woods, btw has spark arrestor & lights, tank just under 2 gallons is sized for AMA Enduro series where rules call for gas stops at 50 miles
450XC is a bigger bore shorter stroke than the the "E", has a hybrid transmission, wide ratio for 1st & 2nd, then close ratio. This bike is king of the hard core blasters that ride with the back end hanging out, a bit happier in dry counter but by no means unhappy in mud. Muffler only, no lights, slightly larger tank than the "E"
525EXC Like the 450EXC with a bigger bore
525EX Like the MXC before it really set up for baha, close ratio trans, 3+ gallon tank, no spark arresor. This transmission is not real happy in the woods as low is tall, set up for open desert! (trick here is, in sand you want to start out in a tall gear! a low first gear just digs a hole.)
okay....so then the 2 smokes wouldnt be a green sticker bike then?/?
I think the only green sticker bike would be the RFS EXC's. I guess I could've just said EXC's since the only EXC's available in the states this year are RFS's. I don't believe there is such a thing as an XC-G, is there?
Oops, my bad. I just looked on ktmusa.com and they do show the RFS XC's as G models. So I guess those would be green sticker, too. Interesting.
yep, the XC's are green sticker legal. Read it in dirt rider review I think, definately read it in a mag review.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
