Brakes
Well my front brake line got pulled out by a tree well pulled loose but still works and I have lived with it a while but it seemed like after using it several times it would get musshy and you would have to pump it some. Would this be needing a bleeding or does it mean it's leaking somewhere? Well while it is in the shop I ordered a Good Ridge brake line for the DRZ400 for him to put on. Well I talked to him today he has the bike running fine and is tunning it up now but that the brake line wouldn't work because the master Cylinder has been changed out to a Brembo and is not the same connector. What master cylinders did these have from the factory? He said he was going to try to tie my current one back on that if I wanted another line I would have to get one for that master cylinder.
Anyone know where I would have to go to get one? Will it have to be custom made?
