3x3 and jetting
I have an 05 DRZ SM...got the dynojet sm specific kit and I'm jetting it as burnd said to the specs for stage two.....it never says anything about the pilot jet...am I missing something or do I need to change it?
The FMF/DJ kit stage 2 instructions assume a standard pilot jet is used, so no need to change the PJ. It makes the mixture adjustment with the 3.5 turns on the fuel screw.
However, id you fit a bigger PJ, you can get away with less turns out on the fuel screw and so less chance of it shaking loose or dropping out.
alright thanks!!
Hey guys! I did the Jet Kit mod way back in the day when Dyno Jet kit was for the S specific model. I am still under the idea i should be using a larger MJ than my 142.5 with a 3x3 hole and full yoshi system. Should i go up to a 147 - 150 MJ ?? It feels just a little light on top? :thumbsup:
Thanks a lot
I've got a 155 main in my SM but I'm pretty sure that the SM kit needle is tapered way different from the S jet kit needle. I think you need both the needle and the bigger jet so it runs right through all the RPM's...not just the bottom or top.
Right. I believe the bigger jet takes advantage of the different needle taper. It's a waste to step up to one without the other.
Man, reading this, I think I'll go try some fuel screw tweakage....
So i guess i should swap out the old jet kit for the new or can I just buy the Needle and MJ? I have the 25PJ already installed. Is the SM kit better than the S? More power? :thumbsup: Thanks
you canuse the same needle.just bump the main jet up to a 150.
I was in the same boat as ucantstunt. I had the S jetkit in mine because thats all they had. I sold it to buy the sm jetkit and left the 25 pilot in and it runs a little better. Its just peace of mind.
burned~ U mean the Same needle i have now or use the same needle off of the SM specific kit and bump my jet to 150?
I bought both kits. Bought the s kit first not knowing about the sm kit. The 'sm' needle is on the left and 's' needle is on the right:
Notice the SM is fatter at the end, shorter, and the actual clip notches are lower. I found a marked improvement in the SM needle.
you can use the S needle.do use the bigger main jet.
the SM needle is different for sure,but the S needle works ok.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
