Wheel building
Santa left me a pretty trick adjustable spoke toque wrench under the tree. It was my intent to just make adjustments as needed on our bikes but I am now thinking of building a set of wheels, maybe Black with red hubs for my XR400. Where do start and can I buy all the parts needed?
Oh yeah,you can,just get a copy of dirtbike or dirtrider and order what you need,but just be sure to have your check book in hand,and a valium in the other,cuz dat stuff aint cheap.! XRRon
You could save some money and have your rims powder coated too. :applause:
Is it worth keeping the factory hubs? My spokes came new on the bike already pitted, I assume they use any chromed junk.
i recently laced a set of excels to the oem hubs. i used bulldog oversized spokes. if you are going to go this way you will have to drill the spoke holes in the hubs to 7/32".
sounds more scary than it is. once you have the spokes laced in the hub, they will almost fall into the correct hole in the wheel. it was a hell of a lot easier than i ever anticipated.
if i recall, the frt/rr wheel and spoke kit cost about 400 from ebay. if you go with hubs you will at least double that cost. you could also powder coat the hubs.
btw, i then took the built wheels to my local shop for truing and tire mounting.
If you stick with the OEM hubs you'll never have a problem finding bearings.
Aftermarket hubs sometimes use non-OEM bearings....
Is it possible to sand and refinish the hubs to get rid of the casting marks. Will a good high quality PJ type paint work and how do they finish the factory one?
i believe the oem hubs are painted or powder coated. i have definitely seen various oem hubs that have been powder coated.
my thought is it may take a lot of work to get rid of the casting marks. i would probably chemically strip them first to determine the scale of the casting marks. sand/bead blasting may be a bit aggressive as the aluminum is soft. then using a roto tool and sanding drum i would give it a try. powder coating tends to fill some voids.
