Are you running a Moose/DP clutch?
Guys I installed a full moose clutch system in my 450 project motor the other day. For those familiar you know how there is a special fiber plate that sits over the spacer + spring that goes on the inner clutch hub.....
Well turns out my special plate that came with my Moose fiber kit the inner diameter is too small so the spring doesn't fit through it. Therefore I was fored to re-use that single fiber plate from an OEM clutch. :applause:
Anyone else experience this problem with the Moose or DP clutches? :bonk:
