free exhaust!
i just put my yoshi exhaust and was wondering if any wanted my stock exhaust. im in phoenix or if someone wants to pay for shipping they can have it. email me at its off my 05 SM
email sent
Thanks Bill
I'm in Phoenix too! No thanks on the exhaust.
sweet. you ever ridden out at the tortilla flats? thats my new favorite place. you can get sooo slow on some of those turns. and its freakin gorgeous out there
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
