Primary nut fix -- with pictures
MOD EDIT NOTE:
There are some issues still with pictures that were in a users garage, and linked in a post, like those found below in the OP's article..
For this thread,I provided a link to those pictures. This is a TEMP fix only. Once the archive is taken down, this temp fix will not work. I'll work on something better later.
But the real fix is behind scenes and is something that is on the list of the admins to get done.
Thanks
E.Marquez---- 15 FEB 2012
MOD EDIT #2 Pictures have been re uploaded to the current server. This should fix things till we migrate to a new How To Article format......
E.Marquez----15 FEB 2012
Here are some pictures of the primary nut fix. Image test ignore
The resident TT DRZ gurus recommend checking the tightness of the primary nut. This nut has come loose and caused engine damage (or been found loose before causing damage) on every model year DRZ (2006 models have yet to report in numbers.) See poll: http://www.thumperta...55&parentpage=5
Drain oil and coolant. Remove right side engine case. The right side cover gasket will most likely need to be replaced. Mine did.
The primary nut has a left-handed thread, so it has to be turned to the RIGHT to be loosened. Here's the location of the primary nut:
Primary nut removed:
You do NOT need to remove the clutch basket (as I did for other reasons) to tighten the primary nut.
Clean nut and threads of all oil. Apply red locktite to crankshaft threads:
To tighten the primary nut either:
(1) use an impact gun (which is not recommended, but some of us did it that way anyway), or
MOD EDIT E.Marquez -----12 Aug 2013: Correct wrong TQ value
(2) Torque it to 110 Nm (79.5 ftlb) (this is the proper way). To hold the crankshaft, remove the left side case, and use a 26 mm deep socket (my local AutoZone carries one) or offset wrench to hold the other side. A 1 1/16" socket works as well. Here's a pic of the offset wrench made by 10guy:
Don't forget the red locktite.
Thanks to AZVMAX and the TT DRZ guys for helping me do this fix.
  • Like 7
Thanks. Mine's a '01.
(It wasn't loose, but I didn't want to mention that so as not to discourage anyone from doing the fix! Shhhhhh..... :applause: )
But I'm real glad I checked it. Before I did, I felt as if I was playing Russian Roulette every time I rode.
My impact wrench instructions say not to use it to properly torque a nut, but it did come in handy rattling the nut loose so I could re-torque with a Craftsman torque wrench after application of red loctite. I used the rag stuff method and it worked fine.
My impact wrench instructions say not to use it to properly torque a nut...
I hear ya! But some of the guys have used a rattle gun, so I thought I'd mention that.
BTW, great write-up.
Mine E is a 2001 and the primary nut was NOT loose. I'll do the 2006 SM soon enough.
Excellent job on the walk-through and photos. I'm bookmarking this thread to repost when anyone new asks about the Primary Nut fix in the future.
:applause:
Thanks for the great post. The only thing I would suggest is to mention whether the threads are right or left-hand thread.
Oh, right! This should definately be mentioned. I had read it in some of the posts and still forgot it! Couldn't figure out why the nut wasn't coming loose with an impact gun until I remembered! :applause:
If there's anything else I forgot, let me know and I'll put it in.
Loc-tite cleaning, use a solvent, like laquer thinner or acitone, what even but make sure you have bare metal. Any oil will render loc-tite useless.
The resident TT DRZ gurus recommend checking the tightness of the primary nut. This nut has come loose and caused engine damage (or been found loose before causing damage) on every model year DRZ (2006 models have yet to report in numbers.) See poll: https://thumpertalk.com/forum/showthread.php?t=318555&parentpage=5
garage.php?do=viewattachment&attachmentid=12238
garage.php?do=viewattachment&attachmentid=12237
garage.php?do=viewattachment&attachmentid=12235
garage.php?do=viewattachment&attachmentid=12233
garage.php?do=viewattachment&attachmentid=12232
(1) use an impact gun, or
(2) Torque it to 101.5 ft-lbs. Remove the left side case, and use a 26 mm deep socket (my local AutoZone carries one) or offset wrench to hold the other side. A 1 1/16" socket works as well. Here's a pic of the offset wrench made by 10guy:
garage.php?do=viewattachment&attachmentid=12239
great job, thanks :applause::bonk:
That is incorrect,oil will not render loctite useless,I am a industrial mechanic and use 242 loctite everday on machinary that requires it on all bolts,with a little oil as a wet application. Red loctite is a stronger grade it comes in 262 and 272,and 277. Not nessacery to clean completly,a little oil wont hurt,but just a little. And good luck getting that nut off if u ever need to. :applause: But a good idea to keep nut from coming loose.
Nice write up.
Hi,
This is next on my list of Drz to-do's and I have a question. Your post says that you don't need to remove the basket to tighten the primary nut. I'm curious if you can get a socket on the nut as the basket looks to close in the pictures. Also is there any other way of tighteneing it without removing the opposite side engine cover to hold the nut Maybe putting it in gear and holding the brake? Not sure how acceptable of a practice that is or it may cause more damage internally? :applause:
Thanks in advance
Frank
Well, I'm the LAST person whose advice I'd ask on anything other than scratching up the plastic real good. I hope others chime in on this, but I can tell you the little I think I know.
A socket will fit on the primary nut with the clutch basket in place. It's close, but there's enough room. However, I'm not sure an impact socket will fit since they have heavier walls than regular sockets.
Others have used rags in the gears or used the brake to keep the gears from moving. but good mechanics will just cringe at the rag stuffing approach.
When I did it, I didn't realize the left side cover had to come off to hold the gear on the other side. There's a 17mm bolt accessible through the plug on the left crankcase cover which turns the crankshaft, but that does not work to hold the crankshaft.
