Drz400, Ltz400 Are They Related?
Hi guys
Any idea if LTZ400 and DRZ400 share the same heads and if not what’s the difference?
Parts numbers are different. Any advise appreciated.
i think they are because i just put a set of hot cams on my drz 400 and they were advertised for a ltz 400. as far as i know suzuki alny has one head for the 400 and the way they change the compression ratio is by putting diffrent thikness base gaskets :applause:
I don't know about the head but the cases are differnt I think other than that I think they are pretty much the same. I am pretty sure the heads are the same along with the cylinder as I know you can use the ATV big bore kit on a DRZ. You may want to wait for somone else to confirm this about the heads though.
I have an 03 KFX (a green suzuki!) and one thing I noticed is that the countershaft sprocket is held on by two bolts and a plate unlike the big nut used on the DRZ. The sprockets are not interchangable. It also looks like the head is tilted forward more on the KFX but I never actually measured them.
Also, I bought a case saver made for the KFX and it would not fit the DRZ.
The bolt holes are about 1/8" off for some reason :applause:
Hi,
Thanks for all the fast responses everyone. One more thing: I have a chance to buy a head from 04 LTZ400. Will it fit my 00 DRZ 400?
Thanks
So if they are interchangeable the FCR carbs should interchange to then correct? A buddy that works at a KTM dealer says they have an FCR from an LTZ400 that's been sitting in the back for years he could probably get me a deal on. If it should work it might be worth the attempt.
