Wayward Son
how to confirm your pilot circuit setting
It seems like the most common jetting issue that comes up are pilot circuit related.  The following is a sure method to choose the needed changes.
With the bike warm and idling, turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths. This should happen between 1 and 2.5 turns on a fcr carb and 1 and 3 turns on a CV.
If you end up at less than 1 turn, you need a smaller pilot jet. More than 2.5 (or 3 turns on a CV), you need a larger pilot jet.
Choose the appropriate size and retest.
This post has been promoted to a wiki
  • Like 58
  • Angry 2
Guest
This topic is now closed to further replies.
