82 DR250 Kill switch
The kill switch is stuffed on my DR, and the wire doesn't actually go anywhere, and just stops down the back under the seat.
What should the Kill switch be wired up to?.
Thanks heaps.
I just looked at my 82 for you. My kill switch goes from the handlebars to the wiring box behind the front light. Remove the white headlight housing and you should find all the connections there. Black/White goes to Black/White and Black/Yellow goes to Black/Yellow. Pretty straight forward. If it doesn't start when you put it back together then the switch is bad and is probably why it was disconnected. If you need to know were it goes from the headlight housing let me know and I'll look for you. Hope this helps.
I still haven't nailed this yet, some sites say wire a kill switch to the positive on the coil, and others say to the green wire from the CDI, I am completely lost now, and don't want to risk frying the old girl completely.
OK, now I have nailed it. Grafter kill switch wire into + coil lead, and it worked.
