which brake do u use more front or rear
Ive had some concern about the front brake and i dint know to use it or not
:thumbsup: Uhh, no, don't use it. It's bad!
Seriously though, what are you talking about? :bonk:
Always use the front brake to slow down. It is more powerful and slows you in a more controlled manner than the rear. If you use too much rear brake, you'll be slippin' and slidin' all over the place. What sort of issues are you having with the front brake?
railing berms and being able to throw their bikes around with using just the engine holding them back as a brake
If there is a turn right after a jump i use both brakes equally but i usually just use the gears to slow down.
Do you think a pro is going to use the engine braking to slow him down?
No, its either gas, or brake, no in between. Basically, use as much of the front as you can, but use the rear brake as well. If you use too much front, you will slide the front end.
-Phill
how do all the good riders get by with not using the front brake
I am what you call a good rider and I use alot of front brake. everyone does.
You use the front brake? I just use the centrifigual retarder to slow down the rear gyro. Hardly touch the brakes!
dude you gotta show me this gyro!
When you show me that bow spow with the build in muffles bearing
Idk about that one. KInd of top secret stuff.
I don't need it anyways, I'll set the ignition retarder on high and spit roost in your face
:thumbsup:
:thumbsup:
if you can come close to me
I just installed a roost boost. It launches the roost so far. I can roost you from across the track! It gives me plenty of time to turn around and check to make sure I made one.
