old cr250 question.
Hi guys, I'm thinking of picking up a buddies 1986 cr250. Apparently it's engine was rebuilt about a month after it stopped working. He wants 500 bones for it but I'm not sure cause the engine won't run. It has a pipe and some other stuff done. The engine put out 60 psi on a compression test after a few kicks. I don't know if that's good or bad. There is a spark but my buddy thinks it's weak.
If you think that the 60 psi is bad or that this is going to cost a fortune, let me know. Thanks guys.
60lbs is way too low. If I remember correctly the 250's should be in the 150 and up range. Someone can correct me if i am wrong.
If it truely had a top end and it is still reading that low, I am not sure what else could be wrong. Possible bad gaskets or lower end seals.
60psi is a no go.
I'd want to look inside it before I potentially threw money away. You could end up spending a large chunk to put it back to running condition. It might need everything top and bottom, ignition parts, linkage, etc. I've seen those shocks get belled-out (worn out like the bore in a cylinder) and need complete replacement - not cheap.
And even then you'd still wind up with a 20 year old bike.
Might want to save that money and put it towards something a little newer and more sound.
Yeah I think I may have goofed on the PSI. It may have been more Either 60 or 140psi. If it's 60 forget it but if it has the proper compression should I do it?
re- check the compression, just to make sure you did it right. the spark should be blue, and you should hear it snap! if everything checks out ok, and it still wont start, check that it is getting fuel, maybe the carb is all gummed up from sitting.Is it a fresh bore? If not the piston will probably just break again. If it all seems ok and you can get the bike running, give him the 500 bucks he's asking and have fun! where else can you have that kind of fun for that kind of money? Playstation will cost more than that, and it's boring!
Check the water pump housing for erosion. Coolant left in too long has left a lot of those old bikes with ruined right crankcase covers.
Thanks for the help guys. I haven't checked the compression yet but when you kick it over you can feel the compression build up nicely. Before I came to look at it my buddy said he kicked it over 6 times and got 155psi. It's in a few pieces as he was trying to get it running. The fuel lines not connected to the carb, seats off just little things like that. He did say that when he puts ether into the engine it usualy fires up for a bit. He says that didn't work for him do he's suspecting it's the spark. I've had no time to diagnose it but I'll probably start tommorow. Any suggestions?
Oh yeah It's a 1985 cr250R I thought it was a 1986 and I'm not sure what the "R" really means but it has no key for the ignition and no kickstand either. It's leaning on my crf150 in the garage right now. Gosh the difference in height isn't much but it's longer and the rear tire is like twice the stock size on my crf. I can't wait to open this bitch up!
Hey mate, I used to have an 85 CR250 years ago, mine was pretty stuffed and I ended up snapping the frame in half but otherwise not bad bikes.
Check the coil resistance as when I had an electrical prob on mine the coil was stuffed.
The R stands for Racing, it is a full blown MX bike with nothing but the absolute essentials, there was never any ignition barrel or kickstand fitted to it.
That year model was specifically known as the CR250RF
Thanks for your help man, that clears up why the stuff is missing. I'll have the bike running really soon but I do have a bit of a problem with the plastic on the bike. I wanted to try and find a plastic company to ugrade the look of the bike to a newer model.Possibly even changing the colour of the plastic. What if this bike is rare. Should I try and keep the stock look?
An 86 is a great bike,you can more than likely put a 87 CR 250 or 87 or 88 CR 500 swing arm on it with a rear disc and you have a bicthen machine!
Hello again, I think you will probably find that no platic manufacturer will still make aftermarket panels for you bike, your best bet will be for NOS, secondhand or repro fibreglass panels.
Its not exactly a rare bike, but there will be very little after market gear for it because of its age.
hey do you know anything about Honda CRF250R?
The CRF250 has its own forum mate. Have a look in there :thumbsup:
hey man,
check out www.ericgorr.com this site has tons of mechanical info about old cr250's and such. rockymountainatv.com might have the plastic you are looking for.
Yeah I sent the bike out to honda where I bought my CRF. They charged $90 to try and get it running. The spark was fine but they said the compression would jump to 130 then to 0. They said it needed a top end job to get it runnning. They were also nice enough to tell me it needed 940 bucks just in parts to have it all fixed A-Z. It needs a chain and sprocket, wheel bearings, shock bushings, etc.
So I tore the top end off and the piston melted itself to the rings just under the arrow side. The jug and piston are at a shop. The told me they can most likely hone it and hook me up with a piston for about $250 including the gaskets.
I can't wait to get it running. The power valve is funny though. I pulled it off but I don't know how to put it back in. Do I put it back in with the valve open or in the relaxed ( Closed ) position?
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
