a little help please,,Radiator leaks
Ok,I was using a screw driver to straighten tab at radiator to get shroud put back on,and must of gouged radiator :bonk: because it leaks now on left side at bottom end,what can I do to fix it?????Dam was getting ready to ride next week,now I need to fix radiator :thumbsup: Anyone know what can fix a leak????do I need too take it a radiator repair shop or what?????? Please Help :thumbsup:
Is the leak in a tube or in the tank? Either way a radiator shop would be best if you have time. If it is a hole in a tube it can be pinched off.
Well not sure???All I now is that I had hit the Vains of the radiator and thats where it appears to be leaking from,which has me stumped because I have seen those vains really bent in other applications,All i know is that I somehow punctured the radiator with very little effert.Its right above the tank....I Think
You might try a local auto radiator shop, I can't imagine any that can't work with aluminum radiators. And then there is always myler's in utah.
There's a co., people recommend here, that suppose to work miracles. Can't recall the name, it will come up in a search. The turn around time will probably nix your ride next week tho. Considering it's a minor problem I'd probably go local.
maybe it's called myler's??? :thumbsup:
Go here
Go here
What he said ..:thumbsup: Fast service, great work, fast service, willing to work with you on shipping, time lines, needed returns, great service,, Did I mention that have great service :bonk:
Sorry!!!! Never had to use them, and at my age that still wouldn't guarantee I'd remember their name.
No worries roach, just flickin' ya some chit. That is what I do around here. Burned helps people, bronco pisses them off, and I flick 'em chit :thumbsup:
Mylers rocks. Same day turnaround and they do great work.
