front disc screw loc-tite?
I removed one of the allen head screws that holds on the front disc and it appears that there is some kind of "loc-tite" on it from the factory. I am building a new sm front wheel from a stock hub and wonder if there is something similar that I should put on the screws to keep them in place. If I was just imagining that I saw something on there is there anything that someone would recommend or is having them loosen up not typically not a problem.
Thanks for any help
I agree, use the locktite blue, you can buy it at any automotive store or home depot I think.
Blue is the medium holding power, right? Is it still pretty easy to break loose on those little screws?
Yes, blue is the medium strength and is fairly easy to remove.
Use an impact, hand or air to bust um loose.. Or add just a bit of heat before trying a hex key
Something to keep in mind for most of the fasteners on a motorcycle :thumbsup:
