Could you check my re-shim calculations?
-----------Feeler---Old shim (inch)---Old shim (mm)---New Shim (mm)
L exhaust--.009-------.095"-------------2.413------------2.150
L intake----.003-------.075"-------------1.9049999-------1.775
Thanks guys/gals.
Thanks guys/gals.
I checked your calculations using Heckler's spreadsheet (see thread above) and came up with the following:
L exhaust, new shim = 2.36
L intake, new shim = 1.85
I double checked - but you should do it yourself and then re-measure after you've put it all back together, just to be sure.
That sounds much better (not saying it's correct), but if the shim change drops from a 2.413 to a 2.15, that's a 0.263 drop.... anything at or more than .2 lower than factory it's time to consider a valve job.
I just put in his calulation (in the spreadsheet) and for the exhaust it looks like he went to the closet one up rather than down if he goes down then he would have 2.125.
The only way I got 2.36 is by placing in "2.63" for the old shim in mm. Which gave me 2.359.
I have not heard the .263 drop means revalve time...where did you see that? Its an interesting peice of info...Thanks
The intake looks correct.
I have not heard the .263 drop means revalve time...where did you see that? Its an interesting peice of info...ThanksQUOTE]
A .263 change in the valve stem length is a huge change and probably indicates imminent failure. By my calculations (using the spreadsheet) to get a .263 change in shim size would take more than a .008 change in the valve stem length - which is roughly equivalent to going from .010 to .002 on an exhaust valve - a sure sign of trouble.
I doubled checked my calculations again - I'm still showing 2.36 for the new exhaust shim (this is a relatively small change in shim size - which you would expect given that the exhaust valve is only nominal off of spec - .010).
Thanks guys/gals.
I don't know where you got your exhaust shim size from but there isn't any 2.413
Was it 2.40 or 2.425?
As far as the intake you would need a 1.85
the way I got the same 2.413 was when i coverted .095" to mm when i checked his calculations. I am pretty sure that he does not mean that was what was written on the old shim.
the way I got the same answers as him when i looked at this (using the spreadsheet) was by tossing in the feeler number into the first cell in "Measured Clearence:" then in the second cell I placed in the "Old shim (mm)" into "Measured Old Shim:" which does result in the numbers he posted.
And for the final (new shim) I think he looked for the closest number (up or down) to what he got in "New Shim Size:"
not saying this is correct but i am pretty sure that is how he came to his results.
*Just read my PM's and he mentioned that he replaced a camshaft with (not sure what hotcams or R model or some other brand) he also mentioned that the valves were perfect prior to the cam install and after before 'break-in'....just some more FYI
Did you convert your feeler measurement to mm using the center box in the spreadsheet?
The number printed on the shim should be reliable - unless your shim has worn a lot, but then you (probably) wouldn't be able to read the number anyway.
The cam shouldn't matter.
.0955" would be a 2.425mm shim. So, you would need a 2.375 shim.
I use the actual Honda shim sizes and count up or down whichever way I need to go. Each shim size is .001"
This is for the 450 so the part #'s are different but the sizes are the same.
14901-MBB-000 .0472in 1.20mm
14902-MBB-000 .0482in 1.225mm
14903-MBB-000 .0492in 1.25mm
14904-MBB-000 .0502in 1.275mm
14905-MBB-000 .0512in 1.30mm
14906-MBB-000 .0522in 1.325mm
14907-MBB-000 .0531in 1.35mm
14908-MBB-000 .0541in 1.375mm
14909-MBB-000 .0551in 1.40mm
14910-MBB-000 .0561in 1.425mm
14911-MBB-000 .0571in 1.45mm
14912-MBB-000 .0581in 1.475mm
14913-MBB-000 .0591in 1.50mm
14914-MBB-000 .0600in 1.525mm
14915-MBB-000 .0610in 1.55mm
14916-MBB-000 .0620in 1.575mm
14917-MBB-000 .0630in 1.60mm
14918-MBB-000 .0640in 1.625mm
14919-MBB-000 .0650in 1.65mm
14920-MBB-000 .0659in 1.675mm
14921-MBB-000 .0669in 1.70mm
14922-MBB-000 .0679in 1.725mm
14923-MBB-000 .0689in 1.75mm
14924-MBB-000 .0699in 1.775mm
14925-MBB-000 .0709in 1.80mm
14926-MBB-000 .0719in 1.825mm
14927-MBB-000 .0728in 1.85mm
14928-MBB-000 .0738in 1.875mm
14929-MBB-000 .0748in 1.90mm
14930-MBB-000 .0758in 1.925mm
14931-MBB-000 .0768in 1.95mm
14932-MBB-000 .0778in 1.975mm
14933-MBB-000 .0787in 2.00mm
14934-MBB-000 .0797in 2.025mm
14935-MBB-000 .0807in 2.05mm
14936-MBB-000 .0817in 2.075mm
14937-MBB-000 .0827in 2.10mm
14938-MBB-000 .0837in 2.125mm
14939-MBB-000 .0846in 2.15mm
14940-MBB-000 .0856in 2.175mm
14941-MBB-000 .0866in 2.20mm
14942-MBB-000 .0876in 2.225mm
14943-MBB-000 .0886in 2.25mm
14944-MBB-000 .0896in 2.275mm
14945-MBB-000 .0906in 2.30mm
14946-MBB-000 .0915in 2.325mm
14947-MBB-000 .0925in 2.35mm
14948-MBB-000 .0935in 2.375mm
14949-MBB-000 .0945in 2.40mm
14950-MBB-000 .0955in 2.425mm
14951-MBB-000 .0965in 2.45mm
14952-MEB-000 .0974in 2.475mm
14953-MEB-000 .0984in 2.50mm
14954-MEB-000 .0994in 2.525mm
14955-MEB-000 .1004in 2.55mm
14956-MEB-000 .1014in 2.575mm
14957-MEB-000 .1024in 2.60mm
14958-MEB-000 .1033in 2.625mm
14959-MEB-000 .1043in 2.65mm
14960-MEB-000 .1053in 2.675mm
14961-MEB-000 .1063in 2.70mm
14962-MEB-000 .1073in 2.725mm
14963-MEB-000 .1083in 2.75mm
14964-MEB-000 .1093in 2.775mm
14965-MEB-000 .1102in 2.80mm
14966-MEB-000 .1112in 2.825mm
14967-MEB-000 .1122in 2.85mm
14968-MEB-000 .1132in 2.875mm
14969-MEB-000 .1142in 2.90mm
14970-MEB-000 .1152in 2.925mm
14971-MEB-000 .1161in 2.95mm
14972-MEB-000 .1171in 2.975mm
14973-MEB-000 .1181in 3.00mm
These are all the valve shims available for the CRF. The shims are marked in mm but they are rounded to three digits: 1.825mm is acutally 182 on the shim and 1.875mm would be marked 188. As far as the measurements in inches, I carried them out four places. If I would have rounded them, you end up with two different shims with the same english measurement. Must be the shift between the two standards I guess. RR.
I dont think feelers come in inches but i do know mine are "mm" maybe his are inch...dunno
.009 needs to be converted to .2286 before entering it in the spreadsheet to produce meaningful results - IMO
