Two different E cams on microfiche?
While looking for OEM gaskets for the E model. I noticed that RonAyers shows two different cams for the E model. Does anyone know what is the difference between the two are? IF I wanted to put one in my S which would be correct?
Intake and exhaust?
Nope... it actually lists four cams.
( 1-1 ) 12710-29F00
( 1-2 ) 12710-29F10
( 2-1 ) 12720-29F00
( 2-2 ) 12720-29F20
I'm assuming it has something to do with the auto decompressor. [i can't imagine they are competition cams???]
one set is a california E cam.they are like S cams.
you want the 29F00 cams.
Thanks again burned.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
