RB Chromoly Pro Frame
Can You Run Something Other Than The Red Baron Factory Shock On The Chromoly Pro Kit Frame ?
Red Baron Says No. But In There Add It Say It Is A 210mm Shock.
What Makes It Different From Other 210mm Shocks.?
Has Any One Used Any Other Type Of Shock On That Frame ?
redbaron make good shocks, why not just use the one that comes with it?
They Do Not Have The Shock In Stock.
So I Am Trying To Fine Out If You Can Use Any Other shocks.
I am POSITIVE Works Performance will have/make you something that will work.Granted it wont be very cheap but I guarentee it will work loads better than the RB shock.
fox's dh mtb shock fits.
