93 radiator interchangable
i have a 93 yz 250 and i found a set of 01 radiators will they work on my 93 ? they look alot alike any help would be great thankx
im almost certain the bolt holes to the frame are different because the 93 rads mounted lower on the frame and they are different dimmensions but if you bolt them up i dont see any reason they wouldnt work. Im 99% sure the shrouds wont line up even if they do bolt to the frame.
Take the radiators off the 93 and compare them side by side to the 01s. I just put a pair off an 04 on my 2000 yz125. had to make a couple small brakets because the newer radiator bolts up a little different on the back side. After it was all back together you cant tell the difference.
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
