HRC high flo end cap for XR400R. What a difference.
Just installed the HRC/OEM high flow end cap for the stock 2003 XR400R pipe. All I can say is Wow what a difference. I do have a few questions with regard to power and sound for those who have done this change or just happen to know.
1)This end cap is marketed by Baja Designs as HRC/OEM high flow spark arrestor. Is it the same as the OEM 96 version of the end cap re-marketed by HRC?
2) Does anyone know what the approximate power gain is from adding this end cap over stock 3/4 diameter welded in version?
3) It is definitely louder, does anyone know the decibel level produced with this end cap. My guess is that it would test out at around 100db.
This really seems like a great way to help exhaust flow for the money.
Thanks in advance for the feedback.
Sorry- I don't have any info for you but rather a question. Isn't the unit that BD sell *just* the spark arrestor? My understanding is that this PLUS the end-cap silencer is the OEM setup from the early XR4...
I think the spark arrestor (HRC Racing) sold by Baja Designs is the same as the OEM 96-97 unit with the internal baffle removed. I may be wrong. Thumper Racing used to sell a Stealth insert for the 96-97 400 that had the small baffle removed. I had one on an XR600 and it was not too loud. BD sells a baffle to insert in the HRC spark arrestor that quiets it down. On your original 2003 spark arrestor, had you done the Gordon's mods?
You are right, it is just the spark arrestor (HM KCY A1). As for the tip Honda put in with that to dampen the sound I don't Know there are however two small holes meant to recieve an insert. BD and probably others sell their insert for the stock cannister(that inserts into the spark arrestor (as far as i can tell, and seals with a heat activated o-ring). I know of at least two. The one at BD which you have probably already checked is about $100.
I on the otherhand don't want to add any more restriction to my outflow than I have to. I am jetted reletively rich and pose no danger to the engine currently. A portion of my messge was to get an idea about sound levels and the likelyhood of getting a ticket here in Northern California(thus i am interrestd in exatly how many db i am over according to the dyno.
I will probaly buy the BD baffle or at least carry the stock arrestor with me (in the truck) if I get stopped i can revert back in 2 minutes in stead of having to go home.
Yup (i take it you mean drill out the stock arrestor (up to four holes) and keep the set screws around for tuning). I have done most of the mods with regard to intake and exhaust. I still wanted more flow but was to lazy to take the header pipes of and grind out the extra weld material (heh heh heh). Snorkel yanked Jets are big 160/60. I got the okay for the mikuni pumper in a few days.
I was told the HRC Racing end cap was "damn loud" when I was shopping around.
If you are over 96 db, you can be ticketed at most California OHV riding areas, National forests, etc.
Here is recent thread with my experiences;
I ran the HRC high flow spark arrestor by itself for one ride. Was a little too noisy for me. Then installed Quiet-is-cool baffle into HRC high flow spark arrestor and this combination tests at 92 dba. I could not feel any significant power loss with or without the Quiet-is-cool baffle.
Great info oldturtle, I thought there could have been a thread for this topic.
Exactly what I was looking for in the way of information.
Yes I agree, the spark arrestor is a bit loud by itself. But seems to REALLY perk things up.
Just checked out quiet is cool. The tip that they sell is cheaper than that of BD by half. :thumbsup:
Along with the 400 I have a 01 650R with the HRC insert. My understanding is that the 650R with the HRC insert will just pass the sound test, some pass, some don’t. My 400 with the 96 insert is louder than expected, but not as loud as the 650. If anyone has had their 400 with the 96 insert tested I too would be interested as to the outcome.
I have a 04 xr 400 with the larger late model end cap that I got from the dealer , alot better than stock and more zip , no problems at any parks or rangers.. do the 160/60 jets and adj . the valves, remove air snorkel and enjoy...
Don't attract attention to yourself by doing anything stupid and you should be alright
Thanks J very helpful.......
Yeah all the people I've seen checked for sound were people spinning donuts with their quads in the camp/staging areas or the jackasses wheelieing down the main road or guys that rev the piss out of their bikes when they're warming them up first thing in the morning. I have loud pipe and haven't had any trouble with rangers or sound because I don't attract attention to myself
I agree,
I see that mostly from teens on quads and posers.
I never been to a sound test, but I can compare to other pipes I have. I have used the 96' SA on 4 XR400's, also tried a BigGun Race, White Bros pro meg, FMF MegamaxII.
The stock 96 w/o baffle runs really good and was by far the quietest. I would guess borderline on the 96db test.
FMF next up the sound list, Best compromise if you don't have to be 96db,unfortunately they don't make it for the 400 anymore.
Biggun is real loud, throttle response is much better than others.
WB is real loud, mid-top power is much better than others.
None of these is as loud as my WR426 w/o baffle was.
At Dual sport rides I run the 96 cap and take the Vortex baffle that I can stick in it if I need. Sticking the stock 98-up cap on would require jet changes.
  • Similar Content
    • By Kev_XR
      If you own an XR250, many of these tips will apply, however, the carburator jet sizes will be different.
      It really helps others answer your questions.
      I will fix them as time allows.
      Until then the Search Feature and enter "kevin's xr400 mods".
      The results will bring up most of the links.
      Here are some frequently asked questions I have answered before.
      Which XR should I buy?
      The longer the straights, the taller the hills, the deeper the sand; the bigger XR you want. The tighter the trail, the smaller hills, firmer terrain; the smaller XR you want.
      The XR400 has a great motor that will pull you almost anywhere. You can be sloppy on a hill climb on an XR400, where you have to keep the 250 singing. The XR400 weight is most noticable when you drop it or try to stop it going down a long downhill. (Moooomentum!)
      The XR250 feels like a mtn bike compared to the XR400. My friend rode his XR250 for years before decided he needed more power. Even then you can add a 300 kit and get good power.
      If you were heading to ride fireroads in Baja, I'd tell you to get the 600/650.
      To the tight woods, get the 250.
      A lot of both, the 400.
      Dual-sporting? Go bigger for more freeway, but don't show up at the trailhead with too big of a bike.
      All of the XR's are great. Pick the one that fits your needs.
      Gordon's Mods for XR400 (Uncorking the bottle up performance)
      XR400 History
      The changes to the XR400 have been listed here several times. This list appears to be complete.
      In addition, HairyScary discusses how to tell if a part has been updated by the part number. Good tip!
      XR400 history
      Getting the Spark plug out
      It seems the MotionPro spark plug socket does not work on the XR400R, but works on the XR250R.
      There is an OEM tool kit being sold on eBay that seems to work.
      717448 XR400 oil change
      Here is a way to make changing the oil much cleaner.
      This tips is really handy if you have a skid plate.
      XR400 oil change
      XR400 FAQ by Paul Gortmaker
      Paul usually has very good info.
      Small bolts
      BE CAREFULL with the bolts on the oil filter cover!
      An oil covered bolt will not torque at the same rate as a dry bolt.
      The friction doesn't build up, the force simply builds until the threads strip.
      This is the reason many people strip out these bolts.
      Here is an execllent website on bolts, oil, and misc values.
      Did you ever wonder why a 8mm box wrench is half as long as a 18mm box wrench?
      It is shorter as most 8mm bolts cannot take very much torque.
      I highly recommend getting getting an 1/4" socket set.
      I bought the Craftsman set at Orchard (owned by Sears), which tends to sell them for less.
      What is the Snorkle?
      This place has a description and pic, it's easy after you pull the seat. I siliconed a piece of coarse screen (fiberglass) over mine to keep bugs and stuff out. - NORTEXT
      717439 XR400/250 Pre-Filter
      After pulling the snorkle, there is a big hole on the top of your XR400. My friend showed me this prefilter trick.
      767409 XR400 Engine Bog, Pilot jet, and the Fuel Screw
      On XR400's twisting the throttle from fully closed to wide open will cause the engine to "bog" or in some cases die.
      831305 Valve adjustment (Am I retarded...)
      Inspect and adjust valve clearance while the engine is cold (35C, 95F).
      Valve adjustment
      389095 bigger jets (Lists stock jet sizes.)
      96-97 XR400's were jetted assuming you would remove the intake and exhaust snorkel.
      98 and later XR's were jetted assuming you would leave them in.
      bigger jets
      739907 Cheap Tool for Setting the Fork Oil Height
      There are some really nice tools out there for doing this job.
      This tool costs $4.49 at Kragen.
      Cheap Tool
      392932 high altitude jetting
      There are two big factors for jetting, elevation and temperature.
      Allen screws for the XR400 carb
      This lists the screws you need to convert the XR400 carb to use allen screws.
      Allen screws
      Screws for the brake and clutch after removing the stock handguards
      TBD - There is a post with the shorter screw part numbers for after the stock handguards are removed. Use search.
      Very quick engine hop up
      This is a very minimal change that should take less than an hour.
      Most of that time is removing the float bowl (3 screws).
      If you decide to do the full "Gordon's Mods" later, you will need to replace the jets again.
      o Pull the intake snorkle.
      o Add a UniFilter.
      o Pilot jet to 55, main jet to 155. (Assuming sea level and moderate air temps.)
      Source: Motocross Action magazine.
      Quick engine hop up
      Gordon's mods
      Baja Designs Baja Baffle with 96' spark arrestor.
      Pull the intake snorkle, UniFilter, 60 pilot jet, 162 main jet.
      (Depending on altitude and temp.)
      What to add to a new XR400 or XR250?
      Acerbis wrap around style handguards (saves levers and bars as they don't dig in)
      Baja Designs skid plate (Made by Utah Sports Cycle)
      Acerbis fork/disc protector
      Grease headset and rear linkage
      Spend you money on the suspension, not a pipe!
      First get some stiffer fork springs (96-97, 98-99 years)
      Fork revalve (cost: 2 qts of oil & time)
      Shock revalve (cost: oil, nitrogen, shim stack, friend who knows shocks)
      Jetting for Altitude (XR400)
      Assuming at sea level and 68 degrees, you would use a 60 pilot and 162 main.
      At 5000 feet and 68 degrees.
      Jettting correction:
      Main 0.96 * 162 = 155 -> 155 main
      Pilot 0.92 * 60 = 50.6 -> 55 pilot
      Due to your elevation, you have less air and less fuel.
      Your bike will not behave the same as a bike at sealevel.
      First, check the fuel screw. If it does not affect the idle speed, you have the wrong one.
      kevin's xr400 mods
    • By Child
      Can we make a sticky thread of pictures? I've done search for pics but I want to see all sorts of bikes just for ideas on stuff without having to go through tons of threads. Not trying to sound whiny or anything, but I think it would be nice to do what they do in the CRF250X forums with a sticky thread of just pics, no comments or anything. Think we can get one of those rolling here?
    • By kawamatt2
      Ok guys, add one more to the list of riders attempting the USD fork swap to an XR frame. Quite a bit of research here on TT and ebay hunting brought me a pretty good deal on a set of forks, triples, and stem from a 00' CR 250.
      There are a few different options for adapting CR style forks to an XR. Bushings for upper and lower CR triples can be made to allow use of the stock XR stem. Specialty bearings can also be purchased to allow use of the stock CR stem in the XR neck. And finally what seems to be the most common; modification of the stock CR stem to allow use of XR sized bearings.
      I obviously chose to pursue the third option for a few reasons, the most prominent of which is serviceability. I wanted to keep as many wear items at possible as stock parts. This has two advantages; availability and price of replacement parts. $45 dollar a pop "specialty" thin section tapered bearings don't sound too appealing especially when being used on a 12 year old dirtbike.
      So now we can get to the meat of the issue; modification of the CR stem. I should begin by saying that i am NOT a draftsman. I've taken a few classes on engineering measurements but am far from an expert and probably only mildly proficient reverse modeling components. With that said, the first order of business was comparing an XR stem and bearings to a CR stem and bearings. Shown below.
      A little closer look at the XR setup.
      And the CR setup.
      Now to get out the calipers and model up the stock CR piece. I used a cheaper set of calipers and suspect their tolerance is +/- .01mm. Good enough for gov'ment work though! All dimensions in millimeters.
      Now to modify the CR stem to work with the XR bearings while remaining compatible with CR triple trees. There are a few things to say about why i did some things the way i did but most of the thoughts are included in the notes section of the drawing.
      With a resized stem we run into the problem of mounting the top triple clamp. The hole is too large for the stem. An insert bushing must be made to resize the hole in the clamp.
      Finally what the stem and bushing look like together.
      Last one. The difference in how the top triple clamp is located on the stem. The CR is equipped with a chamfer that provides a stop for the tree while the XR's triple appears to be limited only by the threads for the castle nut.
      So... would like to hear your opinions on the execution of the stem modification and bushing. I think having these drawings will make it simpler to have the modifications performed as opposed to asking the machinist to completely reverse engineer the part him/herself.
      And a final query: Anyone know the thread callout for the two threaded portion of a stock XR steering stem? My drawings show the outside diameter of the threaded portions and i have a cheap plastic pitch gauge that tells me a pitch of 1.0 but i am looking for something more concrete than what i have.
      Thanks for your thoughts and opinions.
    • By ATJ_Number_1
      I'm on strike 2 here but thankfully this isn't baseball.
      The reasoning and my history. If you haven't figured it out yet I've done a crap load of work on these motors over the last 7 years but they have had 4 wheels around them. In the EX world there are a lot of carburetor options and although many are great there's a cheap alternative that runs 95% as hard as the high dollar options, some even liking it better then aftermarket. When I joined up here in the 2 wheel club I was shocked that the only accepted option was $400 for a 36mm Mikuni Pumper that isn't any bigger then stock! That cheap alternative for the EX is an 04-05 trx450r carb. It's 42mm round slide Kiehin piston-valve with accelerator pump and a mildly modded 400 loves it with a surprisingly strong bottom end yet. Yes I said 42mm!
      So as I build my XR4 I already know that I'd be shooting myself in the foot if I settled on a 36mm carb because I like bigger bores and cams and this motor likes bigger carbs. Makes sense, it is 400cc. Don't get me wrong though, the Mikuni is a real nice pumper for a stock bike and would seem fine on a well modded machine too but this 4 stroke is like every other one in the world in regards to when you go big inside, you want to go bigger outside or you're missing out.
      Whether the info is appreciated or scoffed at I'll post up my findings one by one as I try to find viable alternatives. When I say viable I mean still being able to use the stock environment and not needing a ton of work. I'm sure collectively this is not a new idea to search for such a beast but I enjoy a good project and I like cheap alternatives when they produce results.
      Currently the "test bike" is a 2000 Xr400r, snorkel removed, Uni filter, stock engine, stock headpipe and a 4" supertrapp slip-on with 11 discs.
    • By XL100allnightlong
      Just wondering if there is any tricks to polishing the stock headers on an 02 xr 400 to bring back the original copper color? If not ceramic coating them sounds like an option?
