How good is the 450xc?
I have been riding Yamaha's for a while now, and thinking about the 450xc due to the fact I like to race desert, I would greatly appreciate any feed back on owning a KTM.
Thanks in advance
Unless Yamaha decides to take the awesome YZ450F, soften the suspension a touch, add e-start and a lighting coil, put on an 18" rear tire and add a sixth gear with a low first gear... the XC450 will be the best desert bike on the market.
There are other bikes out there that beat the XC450 in specific areas, but overall, the XC450 is it.
it's real good. how is that?
two of my buddies ride wr450's all tricked out and set up for baja.
they each took a spin on my bike and where amazed how planted, nimble and light it felt.
the motor is also very strong, though the wr pulls it on a really long wide open straight due to the wr's wide ratio tranny.
But I really do not need to go over 90mph anyway.
don"t "f" around get the 525 i had a 450 and a 525 the 525 is the way to go and its only a few more dollars...............
What kind of hp is this bike putting out? I weigh 200lbs and ride pretty fast, I also like climbing hills, how would I compare it to my yz450 heavily moded for offroad? I'm not expecting the same power, but is it close?
I only have 3 hrs. on my 450 XC, but can't tell you how impressed I am w/ it. It really feels like a MX'er that's been modded for off-road, rather than an enduro-type bike.
It feels much lighter than it's real weight, has plenty of smooth power (but not near as tiring as a YZ450), and the suspension is surprisingly good stock - it doesn't beat me up near as much as my resprung/revalved YZ does. There's a gear for every situation from climbing walls to flat-out hauling, and the e-start, kickstand, and pre-wiring for lights are nice added conveniences. It's also much easier to work on (so far) than my prior Japanese bikes, w/ very nice hardware and design that's obviously done by people who actually work on bikes.
The 450 has a lot of nice benefits over the 525, which seems to be a very slightly modded MXC:
- short stroke engine, which is less tiring and makes the bike lighter feeling/more agile
- 18/20mm adjustable billet triple clamps
- slim ergos w/ just enough gas for a 2 hr. race, vs. the oversized tank on the 525
- cooler graphics :thumbsup:
How good is the xc? Its about as good as it gets.
You really think a 525 will outrun a 450XC? I would bet that up to 75 or so the XC would outperform the 525? Certainly a lot more entertaining to ride!
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
