Throttle wobble
I've got an 06 450.
The twist throttle seems to have a lot of liner play. Not rotational, I adjusted that out, but side to side. So much so it's annoying. If I move the throttle assembly in (towards the center of the bars) the end of the bar stops the throttle play but it also makes it stick so that's not a good solution.
Anyone else have this problem?
Any ideas of a fix?
dan
Get an aluminum/rollar bearing unit? :thumbsup:
You won't notice it when you ride. Don't stress about it.
when you move it in and it sticks is because your against the bar. some side play is to b expected. alluminum throttle tube will probably help you out. but you need to expect a little side play
