JD Leak jet
I have just purchased a JD Jitting kit , plus leak jet kit . I am not sure what leak jet i should put in , or even if i need to. I have had some low end bog on my crf 250r 06 and i am trying to tune it in. I have put in a
180 main
45 pilot
Fuel Screw 1 out
Blue needle on 5th from top
300 ft
between 0 - 5 Deg C ( 32 - 41 F )
Any info would be appreciated , as i do not know very much about the carb.
Cheers.
180 main
45 pilot
Fuel Screw 1 out
300 ft
Cheers.
First off congrats and welcome. Im impressed you got the carb out of that beast without any questions on removal. I had to ask a bunch of questions. Good going :thumbsup:
Im not going to be the best advisor, others will chime in, but a 180 main seesm abit high for your conditions. Im in Ohio, similar elevation, same winter temps. I guess the missing piece of info is "How does it run set like that?"
What size leak is stock -70? The carb is bigger now so the jetting must be very different.
Its got a 55 leak at the moment,
Standard JD settings are 175 main , red needle on 5th from top on the 06
In conditions under 50 deg f put the blue needle 5th from top and go one bigger on main jet ( 180 is the next size they give ).
