Stripped Bolt
The long bolt that holds the oil filter cover on stripped out...Looks like it goes all the way into the engine case...Any ideas????
tnx
tnx
Hela(sp) Coil should fix it. But you may want to talk to a bike shop first.
you wont be able to do much with the coil because of the long shaft bolt.
maybe you can try a slightly longer bolt..see if it catches some treads
If you can find a long enough tap (or weld a bolt to a tap), you might be able to bring the threads back. Very unlikely as they are pretty thin.
I have not looked yet, but could you drill and tap threads on the first part of the cover and use a short bolt? It just would not go all the way through the primary case.
Buy some new bolts. Hopefully the case is o.k. and the bolt took the hit.
1. Use the Skinny part of the Slide on a 6" pair of Calipers to measure the Depth of the Hole. (You can use ANYTHING skinny Enuff to get in there and mark it and measure the Depth)
2. Compare the Actual Depth -of the Hole- to the Length of your Bolt.
3. If the Hole is longer, find a Bolt that is NOT TOO LONG/Hopefully 5-10mm longer and try it.
4. DO NOT OVER TIGHTEN! Torque per Spec's!
5. Go to Aluminum Bolts in the Future to avoid this...use "Anti-Sieze" on them!
Good Luck!
Manny
Thot about tapping and putting in a shorter one, question is :is there enuf bolts holding that case on there that u wud not need the one thats stripped as it goes all the way thru the side case.??
about 3 or 4 threads came out on the bolt, so don`t know if a longer bolt wud work, even if ones available..
This bolt was not overtightened, it just went.
I would measure the depth of the hole and see what you have to work with. You should have something comperable to a place we have called Tacoma Nut and Screw. You can get any diameter, thread, and length. Just take the old one in and tell them how much longer.
You might get lucky and have enough threads to just go longer.
They take something along the lines of 10-12 -INCH-POUNDS- if they ARE NOT holing the Cases together. Check the Book.
That really sucks man!! I have noticed that the bolts don't hold that well either.
But thanks for telling us, you will save alot of people from doing the same thing. I wish you the best
-astro-
