4 stroke pipe question
Maybe you guys can help me get it straight. On a 2 stroke it seems like you change the header part of pipe with an after market header for performance gains whil the silencer isn't as important....but on a 4 stroke you change the silencer for max gains while the header isn't as important. Is this true? Also is the pro circuit exhaust the way to go on the 06 KXF? I tend to trust Mitch but who knows.
sorta true, the silencer does do alittle on a 2 stroke but the header is the main thing, but on the four stroke you can get the lowboy (pc) header that adds bottom, or theres the powerbomb(fmf), and theres the normal (pc) system, but yes the muffler does the most on a thumper but the header depending on which one, does do alot also. i have pc gp lowboy on my rmz.
Thanks, the reason I'm asking is for cost of course. If most of the gain comes from silencer maybe I'll try to get away with not buying complete exhaust.
get the complete system...most pipes use a better design than stock..they use a step system..smaller than getting larger to the rear while still trying to keep alot of back pressure for low end...just get a complete system you'll gain more from it
OK, I'll get the complete pro circuit. Maybe I can get it in aluminum instead of titanium to keep cost down
I just got thr PC ss heaser & silencer for my 06,I still need to check the jetting etc...,but dam it seems to be so much more responsive ,I paid 538$ ,as far as I know the ti is just lighter,as copaired to stock ,the ss alu seems to be the same,hope it helps and good luck :thumbsup:
ya TI vs ss wont give u any performance and its hardley any weight differnce...PM me i can get u a deal on any pipe
yep definitely buy full system, even though it is mostly the silencer i would reccommend a full system.
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
