Drz headstock bearings
Hello All,
I have recently changed my stock bars to a set of renthals, I now find when i am riding along the bike fells like it wont set dead straight it feels like it is tipping to one side.is it just me? how wouldf i no if my headstock bearings were gone?
It's highly recommended that you grease the steering stem bearings with waterproof grease, anyhow. The DRZs are famous for coming with little or no grease on them, from the factory.
So now you have two reasons to read this...
Steering Stem Bearing Maintenance
The only way to know for sure is to inspect them.
You can check the bearings by having the bike on a stand - front wheel off the ground - grab the forks and push and pull them. If the forks have any play, the bearings are toast. But as said above, disassemble and grease them. They need it if the bike is old or brand new. Belray waterproof grease.
Hello All,
This may seem obvious, but are you sure your new bars are perfectly centered in the mounts?
I had the same feeling on my S like the bike wanted to slide out in corners. It's your head bearings. They are either to loose, tight or just plain worn out.
would the handle bars make it go like that if they were lighter? my dealer told me it would be around 150quid to replace my bearings.i dont think its them because i cant really feel any movement
I just greased mine last week and after I got it back together to book specs it was "notchy" feeling. so I just re-did the grease job and put it back together with a little less-than book specs and all is well now, just had them a little too tight.
BTW- my bearings looked good - just not very much grease
one way or another you should at least inspect your head... err i mean, steering head bearings
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
