FCR conversion the "burned way".
heres the part number list for using the sudco aftermarket fcr-mx.
sudco part needed-
1)016-925 39mm fcr-mx w/choke no tps.
2)021-216 FCR adapter 2-3/8 carb to S air boot
3)021-439 o-ring for adapter
4)017-262 EMN needle
suzuki oem parts needed-
1)'E' Intake Manifold: Suzuki p/n 13111-29F00, Pipe,Intake
2)'E' Manifold Clamp: Suzuki p/n 09402-58208, Clamp
3)vacuum port nipple to retain S petcock Suzuki p/n 13685-29F00 Union,Intake Port **
this carb comes standard with the following-
200 main air jet
160 main jet
EMR or EMS needle
45 pilot jet
100 pilot air jet
remove the standard needle and replace with EMN clip 3.if running a open aftermarket pipe use the standard 160 main jet.if running stock muffler 155 main jet.
Link to product in TT store (ships free!)
http://shop.thumpertalk.com/product_p/int_keihin_drzfcrmx.htm
sudco part needed-
200 main air jet
160 main jet
EMR or EMS needle
45 pilot jet
100 pilot air jet
016.925 $466.00
021-216 $35.65
021-439 $3.68
017-262 $3.14
13111-29F00 $9.98
09402-58208 $2.51
13685-29F00 $5.41
These are the prices from Sudco's site and ronayers.com.
Total $526.37 + shipping costs
Burned, thanks for the information.
Thank you very much! It's great to see it all layed out like that as well as you covering your butt from answering this question 10 times a day!
:thumbsup::thumbsup::bonk:
Also - no need for the Sudco throttle cables which are listed in their kit? The stock ones will work well enough I assume. Also the S petcock will work for this setup instead of the E? Thanks again!
Thanks guys. Saved us all a lot of searching and asking a bunch MORE questions. :thumbsup:
stock S cables work fine.
i personally very rarely use them.usually only when a customer has bought one.i end up with extra stuff i do not need.
i can set you up either way.the setting will different than what is listed here for our altitude.
Thanks Eddie! :thumbsup:
I'm currently running your recommended DJ kit/3x3 upgrade on my 04 S. I also have the full Yosh RS-3 SS. :bonk:
Now I have a question...
Roughly how much HP (ballpark) is this FCR conversion going to buy me?
:thumbsup:
:thumbsup:
Burned has posted dyno graphs of exactly what an fcr will give you over a mikuni with the 3x3 mod. Do a quick search and you will find it.
Not only is 3 hp quite a bit considering where it starts out from but it is not only about the hp, the responsiveness of the fcr is way better than the cv.
This topic is now closed to further replies.
