Setting Up An Enclosed
Trying To Figure Out The Best Way To Set Up A 6 X 10 Enclosed To Get The Most Space And Storage.
I kept mine simple. I mounted two ATK bike shoes on a piece of 3/4 inch plywood. They're staggered so that the handlebars don't interfere with each other. I can take the plywood in and out as necessary if I need the trailer for something other than the bikes. I placed a bar across the top front that I hang my riding clothes on. I placed tie-down rings around the walls and on the floor. And for things that won't hang, I simply use gear bags. I haul two and sometimes three bikes with this set-up.You may have something much more elaborate planned, but this set-up works for me.
Here is mine. Its a 5x8 enclosed. I got a 5x8 rubber mat from tractor supply for the floor. Works great. Wood shelf up front. Wire basket under that and on one of the walls. Hooks down the side for clothes to hang on.
It may not be big but I can get 2 full size bikes and a mini in there with lots of room for gear. Isn't organized with all that in there but it pulls awsome.
Outside view
RH side
LH side
shelf in front
Permanent tiedowns
