RMZ450 leaking oil
My 450 has started leaking oil at the drive axle at the front sprocket.
Can I change the gasket/bearing/orings (not sure what the parts are called) that seals the axle from the motor without out opening the motor? I sure hope I can.
If possible, what's the easiest way doing it?
They Output Shaft Is What It Is Called Replace The Seal And Orings Easy To Do.
TAKE THE SPROCKET OFF PULL THE COLLAR OUT POP THE SEAL OUT HOOK THE ORING'S AND PULL THEM OUT AND REINSTALL NEW PARTS.
