New tip
I know most of you have probably already discovered this but I will post it anyway. When you are putting the top end back together and you get to where you need to put the cam in, try this. Do no install the rocker arm(or if it was already on take it off) until you put the cam chain on the cam sprocket. It makes it loads easier. Hope this helps guys.
