05' crf250 suspension
the suspension is stiff...particular the fork it wants to deflect..stock..150lb prolly 160 wit gear. i was wonderin if a lighter weight oil would help in the forks i know that it wont do much and particulaly helps in the 3/4 to bottom of the stroke so help me out id rather not respring
You're about the right weight for the stock springs. Valving is fairly stiff and would be the way to go but if not just lower the oil ht. some.
doc
Lighter oil would be hard to notice. Doc is right, just lower the oil height a little. See if you can dump about 10 - 20 cc out and go from there.
