LA Sleeve
With all of this talk about the BBR and Tak bore kits, has anybody used the LA Sleeve kit?
Pros?
Cons?
I have the wiseco kit, which I think is the same as LA sleeve deal. The disadvantage is that you have to have the cylinder bored and resleeved which costs more than buying one of the trailbikes kits that come with bolt on stuff.
I have the weisco kit 120 as well,
aren't the trailbike kits 115's and lower compression ?
Yes the tb kit is a 115, but $ for $ it is probably a better buy, although I haven't ridden one. If you can bore and sleeve the stock cylinder yourself, the wiseco kit wouldn't be too much more expensive compared to the others.
