DRZ400 Lean Idle? jetting check
Hi I am looking for some clarification and suggested jetting.
I have a 2000 drz 400E the original owner drilled out the OEM exhaust baffels and jetted it to run quite well. 165 main jet, needle says "OBDX P" clip 4th from top. I live @~500', Coast enricher is intact.
I recently installed a full Yosh SS system RS-3. and I am wondering if I need to change anything? at idlel the head pipe glows red in daylight. I know it is thinner and will get hot... but the Yosh instructions do caution about "head pipes glowing visible in normal light may indicate an excessivly lean condition that must be corrected"
So my question is what else should I check? What should I have for Pilot jet, air jets, fuel screw setting, etc? I would like check for and correct any "excessivly lean condition"
Thoughts on the PAS? or extended fuel mixture screw?
Thanks for any help
its a CYA warning.does the bike idle well?you need to move the clip to 5.
wow that was quick. Yes it does idle well.
I will try 5 from the top? Is this needle good/correct? Is there anything to be gained by JD or other needle? I'd apprecieate your opinion on the needle?
I forgot to add snorkel is removed.
Thanks for your help!
that is the stock needle and clip position.it works ok.
JD kit is a good choice.you can also use a EMN needle.i use it with very good results.
  • Similar Content
    • By Sammy_1101
      Hi Guys,
      So I recently bought a 1997 XR400. I've done some research into getting more power through some basic mods and rejetting the carbs. Though all of the ones I've found have been for post 98 XR400s so the stock carb set up is a lot different. Usually people are opening up the airbox, exhaust ect. ect. and Jetting their carbs up to 160/162 for mains around 60 ish (I think) for the pilot. However for the 97 model this is close to stock for the jets.
      So essentially what Im asking (Just to cut to the chase ) Has anyone got a 96/97 (maybe 98, not sure) XR400 and has done these similar mods, and what sort of jetting have to done as a result.
      Thanks in advanced, also its my first post so apologies if I havent done everything correctly.
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
