set sails for a kx500!!
(kx 5) For Big Boys With Big Balls...and They Will Smoke Any 450 4stroke.if You Like Tree Tops Just Give It A Bruppp In 3rd.(youll See)!!!!!!!!!!!!!!!!!!
I have a couple guys I ride with that have KX500's and my WR450 will wax their butts. I'd stay with the four stroke if me.
(DUDE ETHER YOUR HIGH OR THERE R WHEN THEY RACE YOU... THERE IS NOWAY YOUR WINNING) SORRY WE HAVE A FEW KX 500 AROUND HERE AND IVE NEVER SEEN THEM BEAT,,,, I WISH I STILL HAD MY KX 5 YOU WOULD EAT ROCKS(HARDCORE) ILL LOOK FOR PICS..
Check out the Service Honda CR500AFX its expensive but sweeeeeeeeeeeeeeet!! servicehonda.com. lots of $$$$$$$$ though!
SORRY,boogieman I've had both and the KX500 has nothing on the new 450's unless your going strait.I love the kx500 power but they handle like crap in the tight single track..Put that motor in a kx250 frame and you'll have a good bike.I remember a few hillclimbs where I just smoked everyone but soon as the strait was gone so was everybody else.
I don't think the 700 intimidator is set up to smoke a KX500. I believe it is a mountain goat. :bonk:
I believe dirt bike magazine did a review on them last year.
If its green its smokable :thumbsup: sorry had to do it :thumbsup:
I have an 04' KX500 I'll sell you. It definitely out accerlerates every bike from a rolling start, the 4 strokes hook better from a dead stop. 4 stokes also rev way higher than a big bore 2 stroke. It doesn't beat 4 strokes(450's) by much as you think,don't let anyone exaggerate.
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
