Help needed... is this store reiliable?
I am not familiar with them, but the tt store ships internationally. If there is anything from a Canadian manufacturer (hindle, kimpex) or store (motovan, royal distributing, tucker rocky...) that I can help you with, please pm me.
I have ordered from them, paid with PayPal and the goods arrived in the UK within the week.
I have also ordered from the TT store, I have had problems with them, and have had an order not arrive, because it was wrongly addressed, but they did, much to their credit sort all the problems.
But they have never been that quick to the UK.
But remember that TT will price match.
Neil. :thumbsup::thumbsup::bonk:
TT = PRICE MATCHING :thumbsup:
kk, i guess its time to support TT :thumbsup:
Neil, do you remember shipping rates for europe? What did you pay?
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
