new to four strokes.....
i just bought a 04 450r
I bought it with the carb off of it and after i put it toget her the bike would not idle unless the choke was on. i took the carb all apart and found nothing wrong, so i pulled the metering rod all the up and got to it idle with the choke off. i just rejetted it (the metering rod is still all the way up) and now it idles and starts fine, but if i throttle anything over idle it backfires out the exhaust. i have checked the valves and they are fine. i have never owned a 4 stroke and i am not sure what else to do....
also are is there any air fule adjustment screws on these bikes or just the idle screw?
It sounds like it's way lean on the pilot. What jets are in it? The fuel screw is the small flat head screw sticking out the fuel bowl on the front of the carb (facing down). It may be turned all the way in.
well that entire screw is missing so that may have alot to do with my problem .
not that this matters now but my jets are 170 main and 45 pilot. but i guess i will install that screw and start again with the stock jets. someone was telling me that it is possible to get that adjustment screw so you can adjust it with your thoum instead of a screw driver?
Bike won’t start after a crash
Pilot too lean
Idle set too high
Improper starting procedure
Bike wants hot start button
Bike runs on or won’t idle down when throttle is chopped
Idle set too high
Air leak intake or engine
Pilot too rich (when bike is hot)
Bike won’t start when cold outside
Pilot jet too lean
Air filter is over-oiled
Motor oil too thick for temperature
Bike sputters/won’t clean out at high RPM
Main jet too rich
Spark plug has debris on electrode
Bike coughs and stalls in slow turns
Pilot too lean
Idle set too low
Valves set too tight
Decompressor is set too tight
Bike hesitates or bogs over deep whoops or G-outs
Float level too low
Carb vent tubes blocked
Main jet splash shield not installed
Float level too high, gas is trapped in vent tubes (install T-vents)
Bike starts but won’t take throttle without sputtering
Pilot jet too rich
Water in fuel
Debris in main jet
Bike suddenly starts sputtering/gas flows from vent tubes
Stuck float check valve
Debris in gas or carb
Bike runs hot/feels slow and flat on straights
Main jet is too lean
Fuel octane low, causing detonation
Bike coughs and stalls when you wick open throttle
Needle too lean
Slide cutaway too lean
Pumper circuit blocked or too lean
http://www.factoryconnection.com/index2.htm
BASIC SUSPENSION SET-UP
FORKS
When installing your forks torque the triple clamp pinch bolts to the manufacturer’s specifications (generally 15 - 16 foot lbs.) After you have installed the front wheel and slide the axle through, push down on the handlebars a few times to insure the axle lugs are seated squarely on the axle before tightening the axle pinch bolts. Improper installation can cause binding in the forks and harshness/stiffness in fork action.
RIDERSAG
Measurement A : Place bike on a stand, wheels un-weighted;
measure from the left inside fender bolt to a point on the rear axle.
Measurement B : With the bike off the stand, place the rider w/gear on
the bike in a normal riding position with feet barely touching the ground. Have someone measure between the same two points as before.
• Measurement A - Measurement B
Remember these are only “General” recommendations. Different riding styles, tracks and manufactuer brands may vary these set-ups. However, listed below is a good starting point to choose from:
125-650cc ..... 100-120mm
Too much rider sag indicates you must increase pre-load to the spring by turning the Spring/Pre-load Adjuster clockwise. (decreases rider sag measurement).
Too little rider sag indicates you must decrease pre-load to the spring by turning the Spring/Pre-load Adjuster counter clockwise. (increases rider sag measurement).
FREESAG
Measurement C : With the bike off the stand and the rider off the bike; push down on the back end and let the bike come up by itself. Measure between the same two points as before.
Measurement A - Measurement C (Generally 25 - 35mm)
If you set your rider sag and your free sag does not fall within the recommended range; a spring change may be needed.
HINT: Less than 25mm generally indicates a stiffer spring is needed and more than 35mm indicates a softer spring is needed.
NOTE: 1" = 25.4 mm
SCOTT EXTEND AIR FUEL SCREW
Pilot too lean
Idle set too high
Idle set too high
Pilot jet too lean
Main jet too rich
Pilot too lean
Idle set too low
Float level too low
Pilot jet too rich
Water in fuel
Debris in main jet
Needle too lean
FORKS
RIDERSAG
FREESAG
NOTE: 1" = 25.4 mm
I didn't get all that, can you tell me again?
