Suggestions please!
hi just got a new ktm sxf ,i need stiffer springs as im fat any ideas or suggestions thanking you :
thumbsup:
thumbsup:
My suggestion; lose weight so you don't need stiffer springs. It's an option, cheaper too. :thumbsup:
How about telling us how much you weigh?
95 kilo
95kg = 210lbs+/- ballpark figs.
You will be close to needing stiffer springs. check the manual to see what the std rates are, failing that I suggest check the "Race Tech" website which has a spring rate calculator based on rider weight and type of riding. They also post the STD setup for most bikes.
Most newer moto-x bikes come setup pretty stiff. Depending on what riding you do you may find your springs are OK. Have you ridden it and noticed any traits you can tell us about??
Cheers, :thumbsup:
thanks ,got a heavier wp spring ,spoke to dealer who races also and to get the sag right i needed the 80 250 spring were good to go now. the front he says will be fine and plenty of a adjustment to be had there too .
