kasea clutch
:thumbsup: have a problem w/replacing clutch...i was told to tighten the bolts all the way
but when i do that,the rod that comes out through the center does not contact. is there supposed to be a ball bearing inside first, before the rod??
if i loosen up the bolts some, the rod will contact then.. it seems as if the rod is not long enough to contact the arm...
any help would be appreciated,
thanks,
fourtrax2002 :thumbsup:
never mind, i found a web site w parts breakdown,had washer in wrong place
works fine now..
thanks,
fourtrax2002 :thumbsup::thumbsup:
