Annoying Chain Slap
What is causing the annoying chain slap on my bike? I have adjusted and lubed the chain properly. Is it just me or have you guys had similar experiences?
(2001 WR426)
I had what I thought was chain-slap so I decided to loosen the chain. Now there is not nearly as much noise coming from that area. Now i have to lube the front wheel to get rid of that annoying squeal.
Bryce Senff
WMRRA #201
WR426F
TL1000SV
CBR900RR
Oh it's Good to Be Back on a Dirtbike!
Thanx, I'll loosen it up tomorrow and see what happens.
Why not increase the annoyance factor and install a TM Designworks Chain Buffer and Chain Guide? Then you will know TRUE CHAIN SLAP grin.gif!
Y2K WR400FM,Answer top tree w/Accu-Trax clamp,Pro-Tapers(CR-Hi w/ EE handguards),Devol Rad. & frame guards, Guts tall soft foam w/ ballistic cover, 14/52 w/DID VM X-Ring, Kouba-T,Michelin M-12's ft.& rr.,12 oz. flywheel weight, Zip-Ty Racing Link & Shark Fin, Cycra front rotor guard and T.M. Designworks Chain guide, buffer & chain wheels. Street legal except for the non-"DOT" tires.
