How to replace CRF 50 forks
My son bent his fork tubes on his new crf 50. Anybody know the procedure to replace the tubes. Looks like a circlip on the bottom and bolt on top? Is there oil in them. Any manual pdf or anything that would help would be appreciated... :thumbsup::thumbsup::confused:
There is no oil in the forks, only grease. I had to bend back the forks on my Z50R a while back.
1. Figure out a way to get the front wheel not to touch the ground.
2. Remove the front wheel
3. Remove two 14mm bolts on top of the fork tubes
4. Slide down dust seals
5. Remove circlip
6. Pull out forks
7. Punch out spring pin and remove all parts from lower tubes
8. Put parts back on new tubes
9. Grease it up good
10.Stick it back up the fork
11.Put in clip
12.Push dust seal back up
13.Tighten 2 14mm bolts to about 15ft/lbs
14.Pt the wheel on
I am going to give you a site that will help with everything with fifties. Go to minis to the max. click links. save this to your favorites. This site has every company,retailer,forums and how to you will ever need. Go to hop-up how tos located on the far right fouth section down. Go to Dano's bike shop. Now go to the second section on Dano's. On-Line Technical Instructions.Scroll down to Fork Removal and Disassembly. You will need snap ring pliers,allen keys,hammer, small punch, a standard wrench set,axle grease or molly grease. If you buy aftermarket fork legs don't get Two brothers fork leg kit. Not that Two Brothers is a bad company. Its just their springs are made for 120lbs. riders. So if your kid is more which a growing boy will become. The springs will give out. There is nothing wrong with any other product they have. Good luck
You could bend them back but once they have been bent the metal loses its matiblity. They become softer. Don't cut corners it could comprimise saftey. Your son obviously has surpased the stock honda. Welcome to the world of aftermarket. I know the prices are scary at first,but don't cut corners here either. Some things cost more but thats because they use finer products.
I just put minis to the max cause its has all the links to companies and stores for future purchases and stuff.
That PDF is very detailed and has close, clear pictures for each step. I used it to install my extended fork leg kit (Fiveo not Two Bros) and it went very smoothly!
Highly recommend those installation instructions from two bros ^^^
Thanks soo much for all the quick replies. This forum is awesome!!!
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
