Motion Pro fork bleeders, WTF! Need some input!
Just picked up a pair of motion pro bleeders and they dont fit! The package says ALL 1999 and later WP forks with external spring load
PART NUMBER Part# 11-0029
SIZE M.4x0.7
I have a 2005 KTM EXC 450 and when you try to instal them the shoulder on the bottom piece does not fit inside the hole. The thread fits but it wont bottom on the o-ring because the "adapter" part bottoms on the top of the fork. (hope this makes sense!) Anybody else have this problem?
Could it be possible that your bike doesn't have external preload adjusters? MP makes two types of bleeders for for preload adjusters and one without preload adjusters.
It has them. its a 2005 model. I think they slipped up on quality control and packed the wrong bleeders?
Are you 100% sure it has them? Not saying it doesn't, but looking at the part numbers, the EXC and SX have different #'s for the caps (even the 05s).
OK, they are not the black ones I ordered, I needed the gold colored ones. Dont have the part number off hand. Just a little FYI.
Careful when you tighten them down! Made from very soft alum and will break apart with the slightest torque. After two sets, I round filed mine. Looking for better quality ones now.
I was able to unscrew the gold part of the bleeder and seperate it from the top. The silver part is treaded. I'm going to drill and tap my fork caps and just screw the silver part into the fork. Just need to go to the hardware store and find out what the proper thread pitch is...looks like it might be some sort of NPT pitch.
They have a couple of diffrent styles other than motion pro on e-bay. Do a search for "fork bleeders"
Probubly 1/8th inch NPT??? (about 5/16th inch diameter)
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
