Clutch Fade???
Howdy all,
Can anyone tell me why my clutch fades. When the bike is cold, the clutch works fine. After riding singletrack and putting around. The clutch spring barely pulls the lever back, and the clutch fade is horrible. Can anyone elaborate on this. Will an aftermarket clutch fix it?
Not sure what you are asking here. Does the clutch slip? or is this just a weak feel in the lever. If there is an unusual amount of play in the lever after exstensive use and after a cooling down period the clutch returns to normal, then the clutch is working fine, It is the rider, in this case YOU which is casuing this condition. There is a whole lot of friction going on inside your clutch assembly. The more you use it (the clutch) the more heat, the more heat the more swelling of the clutch, the more swelling the more fade. So you may or may not need a new clutch. A new clutch regardless of manufacture will act in the same manner if used the same way. You may want to try changing your riding style. Unfortunately for 4 strokes including our little 250X clutch use is clutch abuse. There is so much lugging power in these liitle beasts I am not sure why you are using the clutch as much as you seem to be, unless of course your last bike was a 125 2 stroke.....
I found the stock X clutch to be a very easy to use, smooth, light duty design. It uses a judder spring, weak clutch springs, and small friction pads on the disks to produce a very smooth operation that doesn't bite hard, ever. Unfortunately, a byproduct of that design is weak, slow engagement that generates mucho heat. When I put the 307 kit in my X, it completely overpowered the stock clutch even when cold, so I had to modify it with R model plates and heavy duty springs. Now, it bites hard and generally works awesome for my riding, but it also requires more rider control to use. With a clutch like this, each engage/disengage cycle happens quicker, so less heat is generated.
This pic shows the X and R plates. X on top.
So the R clutch would last longer? I haven't had a problem with clutch fading. I am offf a small two stroke but a big 450 before that. It is hard to get yourself to not need the clutch that much. Just ride by keeping it in mind to baby the clutch. You will learn that it is not needed that much.
Our experience with the X clutch after 2yrs of hare scrambles is that your choice of tranny oil is directly responsible for clutch life and action. We have run Redline super light gear lube with outstanding results. Recently sent our engine to MaxPower for installation of a 302 stroker motor and after talking to Cliff, he wanted to know what kind of strange oil was in the gear box.He stated that the basket looked like new and all clutch components were still in spec. As we were also installing a Rekluse clutch system at the time, I had sent along new clutch fibers which they returned as not needed. I had also contacted Rekluse because I had bought a used unit and needed some info.They told me that the stock Honda plates were the best in their experience. This clutch was used by a young rider coming off a CR85 and even he couldn't kill it with the Redline gear lube. In your case you may have toasted the stock springs and probably should replace them. Some use the springs from the 450 but I am not convinced this is needed. For more info go to and look up "super light gear lube" . Good luck. :confused::thumbsup::bonk::thumbsup:
The clutch is slipping. It seems the lever does not come all the way back out after disengaging the clutch. It seems the return spring is loose, or not applying enough tension to take the cable back. For example. I pull the lever in...Change gears...Allow the lever to return to home position. The lever will not return all the way. Sometimes it gets 3/4 the way back out. If I pull the lever in to the bar and allow it to snap back out it works. It seems the spring is weak.
With the clutch slipping as you describe, it probably is time for a new clutch. What I would do, is remove the clutch unit, paying close attention to what went where. Check the friction plates (the fiber looking ringlets) for wear ie chunks missing, then I would inspect the clutch plates (the metal looking ringlets), check to see that they are not warped. lay then flat on a smooth surface (a piece of glass is excellant) and inspect them to see if they lay perfectly flat. When installing the new clutch or reinstalling the old one, remember, not all the plates are equal. There are two different sizes in there and they have to go in certain order, refer to the manual..... If you do need to replace, the hot set up is said to be OEM HONDA. And the last info to consider is what I said before, clutch use is clutch abuse. These bikes are not designed to be ridden ala 2 strokes, they don't have to be to get the performance intended out of them....Good luck
My clutch handle was doing the same thing and it turned out to be a dirty cable. I used a cable lubrication tool and some WD40 and the clutch handle snaps right out now. You may have already thought of that....
My stock clutch worked fine, but after 1.5 yrs of hard single track, it was time for replacement. My basket had no grooves and I installed a Barnett clutch and I really like it. One of my buddies with a fairly stock 250X rode my bike a few days ago and said - wow, your clutch works great! I have found that Castrol motorcycle gear oil works the best for me. You can always tell if your gear oil is working well when you have two seperate reservoirs like the X - when the bike is Hot after a long hard hill climb, does the bike EASILY shift into neutral? Over two years when running Castrol Gear oil I always say - wow it sure is shifting smoothy, and by the way I rarely use the clutch except when taking off or hill climbs - and to shift into neutral.
are you sure the fibers in the top of your pic are the "X" fibers? The reason I ask is, the original set I pulled out of my 250R looked just like those and the replacements I got from Honda were identical.
I sure hope I have not been running "X" fibers all this time!
Yes, the top ones are the X fibers. Here's another picture, this one shows the stock X plates along with the special fiber/judder spring combo:
The R clutch on the bottom is actually from EBC, so maybe the stock Honda R plates look like the X plates? I doubt it though, I remember somebody else posting a picture like this a few months back and the X plates had smaller contact areas than the R fibers.
Thanks. I did think of that. It does seem my lever is a little sticky. I adjusted it. There is a product call dri-slide. It is usually found in bicycle shops. It is for cables. It is a graphite based cable lubricant. It goes on wet, but the liquid evaporates quickly leaving a nicely lubed cable. FYI. Thank you for the post. I think I found what the problem was. Too much oil in the crank case.
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
