ventura luggage for DRZ
I have been thinking about getting Ventura luggage to fit all my bikes and I note they make a rack for the "E" model (mine is a dual sported "E"). Has anyone used this and how well does it work? I want to keep my bike as light as I can for the majority of riding I do but allow for occasional longer trips (like my trip this August to the Ouray/Silverton area for a week--yahoo!). I have a KLR 650 and a Ducati Monster and I can get racks for them too and use the same luggage. :thumbsup:
Looks good, another nice option for long range riding. I wonder how it will hold up off road?
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
