Who has the DRC tailight and flasher setup???
which DRC tailight goes on the S model the easiest..the metal bracket one or the plastic one?...also who has the flashers that go with it and do they work ok or do I need to buy the wiring kit with it or the relay...thx
isn't there a DRZ model for the DRC in the pulldown menu?
there has been some threads posted on this topic. do a search for DRC.
they discontinued the metal bracket the plastic is what you'll get.
I got one for my DRZ, it was a universal as I was not able to find a DRZ specific unit. It takes a lot of cutting to get it to fit, but you are cutting plastic so it is easy. I am cheap and used the stock turn signals. And yeah, I would post pics, but I am not smart enough to do that here. I have a pic on supermotojunkie.com.
DRC Edge2 & DRC Flush signals fitted on a '05 SM
I dont have the tun signals but I have the smoked Tail light mounted on an '01 "S" with an RM rear fender.
I had the metal bracket and I cut it down to nothing. it took 5 minutes with my dremel. Very simple to install.
<--------Look in my garage.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
