Flat tires and really loose spokes after ride????
Last weekend I went for my first ride at a real motocross track. I was riding harder than I ever have before but I'm pretty much a novice so I don't think I was riding past the limits of the bike. However, the next day when I went to clean up my bike, I had two flat tires, really loose spokes and wobbly rims (I can't tell yet if they're bent). Ok, so I flat-landed a few big (at least they were big for me) jumps but are the stock rims really that weak? Are aftermarket rims recommended? If so, which ones?
Now the real mystery - I know that my tires were filled to 13psi the night before the ride. I just removed the wheels and filled up the tubes to find the punctures and there ARE NONE!!!! The valves are fine but nonetheless, the tires were flat! How's that?
Could be leaking out of the valve core. But im not sure. mine did the same thing. and for next time, check your spokes before you ride and your rims wont get all messed up when you ride.
they do that once in a while after a hard landing..un explainable..but the reason ur spoke got crappy iss because u rode on flats, that ruins spokes and rims in no time
You don't need aftermarket wheels.
Did you actually remove the tube from the tire/wheel to check it? If not, it will seal against the inside of the tire until you ride the bike, then it will go flat again.
If it were my bike, I would remove the tires, replace the tubes, replace the rim strips(at least check them), tighten the spokes properly, and put everything back together. Riding on a flat usually trashes the rim strip and tube.
The bike will loosen the spokes for the first few rides. Check them often. When you remove your tire to fix the flats, replace the stock paper thin tubes with heavy duty ones (there are many available) , and throw the rim strap on the scrap pile. True your wheels with the tire off the rim, and use good quality duct tape in place of the rim strap. Cut out the holes for the rim lock and valve stem with a razor blade. These bikes will pinch flat the tubes because they are so thin and the duct tape adds some tension to the spoke heads and protects the tube better than a rim strap. Once seated the wheels will stay true until you really pound them in heavy rock riding. :thumbsup:
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
