How much risk in buying used cams ?
I know that you generally don't buy used cams with automotive engines but does this apply to bikes as well ? I have an opportunity to but a set of used hotcams stage 2 (intake & exhaust) for $200. Does that seem reasonable or is that a little much for buying used ?
Sounds a bit much to me - I found some older stock brand new stage 2 hotcams for $120 each plus shipping about a year ago. Not sure there's a lot of risk, as long as the hardening is OK, but if you can find new ones for a few bucks more...
Of course you can always haggle and if you get them for $150 or so then its probably worth it :thumbsup:
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
