drz 400 s
i just brought a drz 400 s and it seems very high geared.
my last few bikes were motorcross 2 strokes
and great for bush and hill climbs..
i did some steep hills today and the tyre spun all the way up,
so i will changing the back tyre for sure.
i was also thinking of putting on a 13 tooth front sprocket to make those
hills a bit easyer..
was wondering how much top end speed i will loose as i ride
on the freeway to get to the bush tracks so i dont want to
rev the guts out of my new bike
any help would be great
Sparko, you will get a wide variety of advice on sprocket sizes from folks here. Here is what I have learned about my 400S.
The stock gearing (15/44) is too high for off-roading. I decided to try going to a 14/47 setup first. It was pretty good for offroading, but a little too low for me. It revs out really quick and first gear is almost useless.
So, then I went back to a 15 front, and kept the 47 on the rear. I really like it. It will climb anything I point it at, but doesnt rev up too quick. For me, its the perfect setup. Hope that helps ya some.
I know some people who ride really tight woodsy stuff have gone with the 13 on the front, but for me, that seems like overkill.
Oh yea, and Welcome to TT
I run a 14 tooth front and it works good.
Went with 14/44 and it works well overall.
On the highway I cruise @ 90-100km/hr and it is not annoying at all.
If I was doing tight bush this would be too high of gearing but I don't.
am ruining 14/47 just perfect for everything. tight woods no problem, 100mph cruse no problem, and everywhere in the middle......
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
